Cutting on the diagonal
Postby Jeff » Tue Jun 05, 2018 12:37 pm
I want to cut out a shape of a boat oar.
It needs to be longer than 32 " needs to be36" .I was wondering to know how to set the up the shape to be able to cut it out.
Would I need to use a xy dimension the size of the cutting area and then put the oar design on it and rotate it to fit diagonally on the work piece.
Jeff
Jeff
Re: Cutting on the diagonal
Postby WillAdams » Tue Jun 05, 2018 1:23 pm
Yes, if it will fit, that's the most straight-forward way to do it --- just rotate the geometry which you wish to cut.
Return to Discussion
Who is online
