Adjusting the feed rate
Jeff
Post by Jeff » Mon Jan 07, 2019 2:02 pm
With the new CM software while running the job I want to know how the 10% increase in feed rate works.
So another words If my tool speed rate is 40" pm and I want to increase it to 50 50 ft pm .how many clicks would that be..
Jeff
Re: Adjusting the feed rate
Post by WillAdams » Mon Jan 07, 2019 6:06 pm
I believe each percentage value is applied to the base value, so:
110% == 44ipm
120% == 48ipm
130% == 52ipm, &c.
Please note that it's persistent and if you load a new, faster file, you will want to reset this.
Jeff
Post by Jeff » Tue Jan 08, 2019 11:57 am
Sorry But none of that made any sense to me.
If the feed rate on a bit in a tool path I am running is 40 IPM and I click the 10% up button 2 times what has that done to the feed rate of that tool path.
Jeff
Post by WillAdams » Thu Jan 10, 2019 2:11 pm
It's basic math.
Each time you press the +10% button you add ten percent to the adjustment --- first press is 100 + 10 == 110%, second press is 100 + 10 + 10 == 120%
Jeff
Post by Jeff » Fri Jan 11, 2019 12:15 pm
So is how do I reset it
Why is this kind of information not on there web site.
FYI i called Carbide early this week about the feed rate and had to leave message and nobody called me back.
Do you use the probe,
Jeff
Post by WillAdams » Fri Jan 11, 2019 2:25 pm
Press the button to reduce the feed rate as many times as you pressed it to increase it to get back to where you started --- it's persistent, so you need to revert back to 100% if you don't want the modified speed.
Sorry no one called. Best to e-mail in to support@carbide3d.com
Yes, I use the Probe for jobs which warrant it. We have docs on it at: https://docs.carbide3d.com/assembly/tou ... /userguide
If you have a problem with using it, please send in a step-by-step discussion of how you are having difficulty and we'll try to help.
Jeff
Post by Jeff » Sat Jan 12, 2019 1:14 am
Well I have look at that link several times you provided and there is nothing in it about changing the feed rate while a cut file is running.
I think the lack of of a information on all the features of the CM4 other than probing is to bad.
But that just my opinion.
Jeff
Post by WillAdams » Sat Jan 12, 2019 6:38 pm
Feed rate ought to be documented at: https://docs.carbide3d.com/assembly/car ... userguide/ but isn't.
I'll see what we can do to update that.
