shapeoko 3 max depth cut and feed?
Postby ram » Sun Jan 13, 2019 7:08 pm
hi
before i go spend lot of money on a shapeoko 3 like ask to people that have them and use them whats the max. depth of cut & feed rate you can push the machine i solid pinewood? thinking 3 flt 1/4 end mill this would give a little idea if shapeoko 3 is right for me.
ram
Re: shapeoko 3 max depth cut and feed?
Postby WillAdams » Mon Jan 14, 2019 1:12 am
We have official feeds and speeds here: https://docs.carbide3d.com/support/#tooling-support
Some folks have done better, see: https://wiki.shapeoko.com/index.php/Materials#Pine
Postby ram » Mon Jan 14, 2019 10:55 pm
i was looking for real people cutting with there machines, not a feeds and speeds calculator to start with
ram
Postby ram » Fri Jan 18, 2019 12:41 am
no one here has one?
ram
Postby twforeman » Fri Jan 18, 2019 4:16 pm
Most of the material I cut is 3/4" maple - which is harder than pine. I usually run a 1/4" end mill at 50IPM with a .250" DOC.
My machine is modified a little from the standard S3 so I have more height under the router. I was cutting 2" thick pink insulation the other day.
Prusa i3 3D Printer
Return to Discussion
Who is online
cron
