Rapid Rate
Rapid Rate
Postby Jeff » Sun Mar 10, 2019 11:58 am
In Vcarve pro there is a time estimator . it needs to know that the Rapid Rate of the machine is.
Where can I find out what that would be for the Shapeoko XXL.
Thanks Jeff
Jeff
Re: Rapid Rate
Postby WillAdams » Sun Mar 10, 2019 1:32 pm
This is a setting in Grbl.
The defaults for the Shapeoko 3 running Grbl 0.9 are at: https://docs.carbide3d.com/software-faq ... -settings/
You can check your specific machine / version by connecting to it, opening the Log, then sending $$ and checking the log.
Re: Rapid Rate
Postby Jeff » Mon Mar 11, 2019 11:59 am
That link is probably good for some one that knows what all that means. If that is what it takes to find the rapid motion of the machine then I am out of luck.
I was hoping that is was just a # that someone knows.
Jeff
Jeff
Re: Rapid Rate
Postby twforeman » Mon Mar 11, 2019 6:44 pm
5000 mm/min
Not that difficult...
Prusa i3 3D Printer
Re: Rapid Rate
Postby Jeff » Mon Mar 11, 2019 10:00 pm
Thanks For the reply and Speed rate.
Jeff
Jeff
Re: Rapid Rate
Postby twforeman » Tue Mar 12, 2019 3:47 pm
That's the "default" value. It may be different on the machine.
The best way to know for sure is to open the terminal and send $$ to get the settings and see what $110 is set to.
Prusa i3 3D Printer
Return to Discussion
Who is online
