Cutting oversized stock
Postby woodhobby11 » Mon Apr 15, 2019 12:09 am
So Ive got a customer wanting a sign 45" wide and I was just wondering if anyone has come up with a way to cut oversized pieces as the shapeoko xxl max cutting width is 33". Would love to get some ideas and feedback on this.
woodhobby11
Re: Cutting oversized stock
Postby CrazyBillybob » Mon Apr 15, 2019 1:05 pm
You have to build points into your design to use as index points so that you have a know set of points to start the second half of the job. I've seen some folks us pins (dowels) on the backside with corresponding holes in the bed. Others have 2 or 3 points in the design that they line the bit up with to make sure it's lined up and square.
I would test my setup on some cheap stock before going at it for reals. Especially if it's my first go at it.
CrazyBillybob
Return to Tooling & Fixtures
Who is online
